Connecting Micrologix 1400 through Ethernet
Delete your driver ETH-1 and only use ETHIP-1, then show a screenshot again of the driver diagnostic for ETHIP-1
OK, now open RSLogix and click COMM then System COMM, when the new window opens click upload and then let us know what happened
So I am thinking that if you both are having the issue there is a good chance its a Windows update issue thats killing RSLinx
This has happen to me several times
I haven't found a solution to that specific problem, but I did get it working. I'll update my thread on what I did to get it working. It was a step by step process and could be a windows update.
How could they know? They can't connect with E/IP ;)
(yes, via serial, I know)
You can just check that in channel configurations without being online. See Red... This is a ML1400...
That is, if you have a copy of the program.
Well, I never did check that box (red) in a ML1400 before. Seeing as I have all this setup in my apartment with questionable wiring, I may just do that.
if suppose this is the case, is there a way to reverse it or change it in anyway?
will serial communication work?
although i am not well versed with this mode of communication with ML1400, so any kind of help is very much welcome
Hello, I wish to connect a Micrologix 1400 PLC with a Wonderware SCADA application. I have RSLinx Classic Lite. Is there any other way than...
1,198
91
Hi there I am new with this thing and i don't know how to connect Allen Bradley Micrologix 1200 PLC to Raspberry Pi using USB to RS485 in NodeRED...
2,283
Hello, I have a MicroLogix 1200 controller that I'm trying to get to communicate with a PV 800 (CAT 2711R-T4T). This mostly likely means that I...
2,499
First of all Hi, nice to met you all. I have a problems trying to control my PLC's (1762-L40BWA ser. C and 1763-L16DWD ser. B) with the Panelview...
5,064
