Connecting non-Siemens HMI device to S7
Gusmo
Mar 2006
Eindhoven
Which non-Siemens HMI device (Operator Panel or Touch Panel), can be connected via DP or MPI to a S7 PLC and has a software configuration package, which can access an S7 Project in Step7 and offers a function for creating tags by selecting variables from the S7 Project.
Parker claims to have both MPI and DP functionality with S7.
Esa is a little confusing about the supported functionality with S7. Both MPI and DP are mentioned but not at the same place.
I am sure there are more. I found the two above with google.
Yo Gusmo,
I've been programming touch panels Pro-Face GP2600's, each linked over DP to a S7-315-2DP, for over 2 years now. No linking problems whatsoever.
The programming tool is ProPB3 v6.22. However, there's no integration tool for Step7 (yet?).
Just think of it as an option. http://www.pro-face.com/select.htm
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
69
85
129
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
132
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
258
