Connecting OP7 to Siemens S5 PLC
Johnny T
Jul 2003
Fife, Scotland
642
Does anyone know where I can get those files that you install when running an OP7 from an S5 plc. The files are:
PLC TYPE FILE NAME
AG 90U, AG 100U (CPU 100, CPU 102) S5TD02ST.S5D
AG 95U S5TD03ST.S5D
AG 100U (CPU 103) S5TD01ST.S5D
AG 115U (CPU 941 - CPU 944) S5TD50ST.S5D
AG 115U (CPU 945) S5TD51ST.S5D
AG 135U S5TD24ST.S5D
AG 155U S5TD69ST.S5D
I did have a disk with them on but seem to have mis-placed it. I've tried searching google but no luck as yet.
Anyone got a copy they could email me?
Cheers
JT :)
Sorry the filename thing got all messed up...
Here it is again...
PLC TYPE FILE NAME
AG 95U S5TD03ST.S5D
:rolleyes:
connecting Simatic S5 090U to OP7
Does any body know the cable config to connect Simatic S5 090U to OP7
I need to know the DB15 pin out for the cable.
Dau
looks OK
for info....
AG(PLC) pin-outs:
2 = TTY IN-
6 = TTY OUT+
7 = TTY OUT-
9 = TTY IN+
Hello
There is a"S5100U CPU102"and an"OP7" that we have problem in their communication,we have used"FB51"whitch has been in"S5TD02ST.S5D"file as
you have mentioned in one of your answers,and"DB51"with 256 word and have initiated DW40 of DB1 with KF+1 in OB21 and OB22, and we have assigned DB51 to"INTERFACE AREA"of OP7 in Protool configuration software,but unfortunately we have encountered with the message"NO PLC PRESENTS"Message on OP7.Of course it's necessary to mention that the connection cable has been assembled as in"AS511 e.pdf,as you have mentioned too.Could you guide us in this problem?
Best Regards Ali-Mohammadi
Hello
There is a"S5100U CPU102"and an"OP7" whitch we have problem in their communication,we have used"FB51"whitch has been in"S5TD02ST.S5D"file as
Hello
Thanks for your attention
I received your answer,as you had mentioned type of op7 is necessary for S5 connection,but our op is"6AV3 607-1JC30-0AX1 OP7-DP12"therefore
it ought to be connected,Is there any other reason for this problem?
Best regards Ali-Mohammadi
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
66
73
121
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
126
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
256
