connecting Ps69dpm masterdrive and compact logixs
eababio
Jan 2011
Gaborone
52
does anybody have any experience with connecting compact logix to siemesns master drive using the ps69dpm profibus scanner?\
I changed the bus address on the siemens and loaded the sample program on the prosoft cd to compact logix. also configured the profibus scanner but when i run compct logix with everything connected the Com ligth on the ps69dpm immidietly goes red.
On the Masterdrive CBP2, if comms are good
You should see 3 blinking leds. All at the same time.
Also post the gsd file you are using
the profibus card on the VSD has both yellow and red flashing.
while on the PS69dpm module the Sys light is flashing Green while the COM light is static red.
what do the following refer to in a read_requst tag in compactt logix when communicating with ps69dpm through profibus
DataArea
DataAdr
Datldx
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
66
73
121
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
126
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
256
