Connecting remotely to a logix PLC
JDreamer
Aug 2016
Houston
I'm able to connect to only two ab plcs (1756-L73) remotely that are in the same network than others, I'm using the cmd "route add" plc IP mask PC IP metric 1; then add the driver for each plc IP in RSLinx; if I'm doing the same steps for each plc IP address, why I can't even ping the rest of them?
Please help.
Make sure the gateway IP address is set correctly in all of the devices on your network that you are accessing remotely. This is a problem I've ran into with VPNs and such.
Is the gateway set up done through the usb port to the 1756-EN2T? 'cause I can't see where to change it, the only thing I see is the IP address setting.
Thanks.
The gateway setting is missing will it stop the processor if it's running when I enter the gateway IP?
Hi, I have a new role at my company to support some Twincat PLCs (Older CX units). I'm not very experienced with TwinCat but I'm trying to...
2,337
Hi Guys, I'm trying to connect remotely to a CLX-L61 rack on Ethernet using a 1756-ENBT-A On my router I have forwarded ports TCP/UDP 2222 &...
2,519
I want to connect to RSLinx Gateway running in a remote location from my laptop using Modem and telephone lines ( via Ethernet is not accepted by...
10,720
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
57
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
64
