Connecting Remotely to a CLX-L61 using Port Forwarding on 1756-EBNT
Jul 2007
Kiruna
600
Hi Guys,
I'm trying to connect remotely to a CLX-L61 rack on Ethernet using a 1756-ENBT-A
On my router I have forwarded ports TCP/UDP 2222 & 44818 and still cannot see my PLC in RSLinx.
Has anyone ever achieved this?
Which driver do you use in RSLinx?
The right one is "ethernet devices" (NOT Ethernet/IP).
- [font=comic sans ms,sans-serif]fuzzy logic[/font]
Can you give us some details on your connections? Mainly, are you trying to remotely connect over "residential" internet connection?
Hi TW,
Admittantly I don't know a lot about Routers and port forwarding etc but what i need to do is connect to a remote PLC offshore.
My "test" setup is by trying to connect from my office to a PLC located in my home.
At home I have forwared ports 2222 & 44818 in my router. The PLC has a static IP of 192.168.0.1
In the office the IT Tech has bypassed all firewalls etc by setting me up on a wireless router and assures me the problem is not at his end.
As much as I love to blame problems like this on IT, chances are this one isn't theirs.
Just clarify for me, your "test" is using your residential cable or dsl service and not the connection you will be using for the offshore PLC? If so...
It's always nice to make sure you can ping the the router, but must ISPs block pinging. Another thing I have found that many "residential ISPs block is low level port numbers. I believe they do this to keep you from using computers at your home as servers that are normally accessed since your only suppose to use them to access the internet although they claim they do this for your protection. My ISP blocks ports below around 20,000, which includes the port 2222 that you are trying to access the PLC one.
Now before you go any further, what are you trying to accomplish with your test? Just a little comfort in knowing it will work once your in the middle of the ocean? What type of connection will your offshore PLC permanently have? Will it have it's own or share a connection with a bunch of other equipment? If it will have its own can you go ahead and purchase the hardware?
If this port blocking is the problem then there are ways around it but whether it is worth it or not depends on the answer to the above questions. Mainly, you must get in on a port higher then your ISP blocks. Chances are they are not blocking all incoming ports, it is more of a deterrence. Pretty much your PC will have to come out of RsLinx on port 2222, route to a higher port, go through the internet, hit the router, route back down to 2222. Hardly worth it if your just wanting comfort...
Hi, I'm able to connect to only two ab plcs (1756-L73) remotely that are in the same network than others, I'm using the cmd "route add" plc IP...
1,844
Hi, I have a new role at my company to support some Twincat PLCs (Older CX units). I'm not very experienced with TwinCat but I'm trying to...
2,337
I want to connect to RSLinx Gateway running in a remote location from my laptop using Modem and telephone lines ( via Ethernet is not accepted by...
10,720
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
57
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
64
