connecting to delta plc wia panel master hmi from com2 or com3
reza.akbari
Apr 2015
mashad
Hello to every one
I have a delta plc with model dvp12sa2
As you know this type of plc has 3 coms , com2 and com3 are rs485
I want to connect panel master with plc through com2 or com3 but i cant.
Is there any setting with this model of plc because with ss2 model of delta plc there is no problem and i could connect plc and panel master hmi through com2
Thanks for your attention
48
hi dears at first i'm sorry for my weak English! i connected labview to Delta PLC with DCS Module. and i created I/O server with Modbus TCP...
2,469
93
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
103
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
235
