Connecting to existing SLC500 network
bpoon
Apr 2006
Olympia
Hi there,
I need to make some modifications to an existing PLC program. The processor that the changes are going to be made to is part of a network made up of 2 SLC 5/05 processors. I've been given the existing program, so I have the I/P information (address, default gateway, etc.). I'm just wondering how to connect to the network to download my changes. Do I need to create a new driver in RSLinx?
Under 'Controller Properties -> Controller Communications', I have the 'Last Configured' information with Node, CIP Path, etc. Can that be used to set up a new driver?
Thanks,
Ben
Just use the ethernet ip adresses for each processor, set up the ethernet ip driver for rslinx, and have at it.
We have a new project to setup a control panel with PLC DL205. This PLC should be able to communicate to the existing system with BACnet protocol...
6,865
Can it be done ? I've seen suggestions with routers etc. but surely this would be if I wanted to create my own wireless network ? How do I go...
7,586
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
52
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
62
100
