Connecting to IMO K10S1
elfrider
Nov 2015
Midlands
33
Hi, I'm looking to do a small favour for someone who's plant is running an old IMO K10S1 PLC with a MI2L20C HMI. I've successfully managed to connect to the HMI, but for the PLC I can't find any definitive connection guides. I managed to work out I needed a KLC-010 lead coupled with a KLA-009 adapter (is this correct?), but the KGL_WIN software is saying "PLC Connection Failed" when I click the "connect" button. Connection options are set to RS232C & Local. COM port is set correctly. Is there anything I'm missing? My background is Rockwell & Mitsubishi so I'm confident once I can connect I'll be ok.
Thanks in advance.
I have 2 PLCs. One is networked to our plant, and the other is networked to the first PLC via a 1756-EN2T. I could easily get the second PLC...
81
92
146
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
150
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
262
