Connecting twido over ethernet
Geerto
Nov 2011
Leuven
Hi everyone,
i'm new here at plc talk, so i hope someone can help me with my little problem.
I have a problem to connect my pc to 2 separate twido's over ethernet.
I'm using two TWDLCDA24DRF twido's in combination with the 499TWD01100 twidoport for each twido.
My router is a Phoenix contact "FL switch SF 8XT"
I think the hardware settings in each controller are correct (communication over a normal serial cable is working perfect)
In twidosoft at the connections managment the ip adresses are set as this:
twido1: 192.168.1.196 P-unit/adres is set to @
twido2: 192.168.1.197 P-unit/adres is set to @
ip of my pc: 192.168.1.198
when i trying to connect i get the error message: "communication error, check connection parameters, network cables configuration and controller suply"
all cables are ok, so this could not be the problem
could this be a problem with ip adressing? i'm using windows 7
and i am not an expert in ip adressing.
thanx in advantage
win 7 works fine with Twido.
check your mask address and gateway.
Check that your com port is set to Modbus
see attached
to be able to transfer application from PC to XBTF011110 By serial connection, must using XBTZ915 cable + XBTZ962 adaptor XBTF011110 , please...
3,176
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
54
97
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
105
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
237
