Connecting Two AB HMIs to AB PLC through 1761-NET-ENI Module
gibson
Sep 2012
mumbai
46
Hello,
In my project work i am Connecting two Allen-Bradley HMIs (PanelView Component C600 and PanelView Component C1000) to Allen-Bradley PLC (Micrologix 1200). As ML1200 doesn't have an Ethernet port i have used 1761-NET-ENI module for DF-1 to Ethernet/IP conversion also in between two HMIs i have incorporated a Switch. I just want to know how can i Configure the IP addresses for Both HMIs ? :confused:
Hello everyone! At present, I have 2 PLCs S7200 and 2 HMIs TP170. I want to connect them together. However, I don't know how do I do? May I have...
2,864
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
51
97
Hello, I was looking to store some values from our FactoryTalk Application using Datalog to a MariaDB. I see there is quite a bit of documentation...
105
I haven't encountered problems connecting to a PLC through VM Ware but I am with this particular machine. I'm running Windows 7 on a Windows 10...
237
