Consumed/Produced Tags between 1756-L55 & L71
lrahman
Oct 2017
Dubai
21
Sir,
I have installed 1756-L55 Controller in slot-0 and L71 Controller in slot-1 of Control Logix 13 slot chassis. i can read data from L55 in L71 project via produce/consume tags concept but reverse is not happening. i cannot add L71 controller in L55 project's IO configuration. Please advise any firmware upgrade for L55 or firmware downgrade for L71 to have read/write data access between these two Controllers. Thanks.
Put your L71 into the L55's I/O configuration as an L63 for L55 F/W up to 15, or an L64 for F/W 16.
It will work, as nothing has changed in the Producer/Consumer model ....
EDIT : I am certain I have done this myself a couple of years ago, but I can't check as I only have an L55, an L61, and an L63
EDIT2 : Electronic Keying is not relevant to Controllers, so there should be no "I/O" errors. So long as the producer produces, consumers can consume....
Thank you sir I upgraded L55 FW to 16 and added L64 as disguise for L71 its working fine thank you.
I know this thread is old but I had to. You're a lifesaver, been struggling for over a week trying to get these controllers to communicate. This worked like a charm
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
174
Hi I have been knocking my head against the wall trying to figure out why these two plcs won't talk with Produced and Consumed Tags data. The...
484
Hello all. I have a 1769-L16 that I inserted a 1769-L35E into. I was expecting it to create module defined tags automatically in my controller...
1,816
Hi, Can a tag configured as a Produced or Consumed tag be read or written to with Explicit Messaging? Context: we are retrofitting an AV system...
2,256
Ok, I've setup comms to PLC's that are behind a NAT switch before, but I have not had a PLC behind one NAT switch communicate with a second PLC...
3,436
