content of 1756-OX8I
david90
Apr 2010
ca
202
This is a wrong place to post this question but I'm not sure where else to ask.
What is suppose to come with the 1756-OX8I card? I bought the 1756-OX8I card on ebay and I'm wondering if I'm getting all the accessories.
1756-series I/O modules don't come with wiring arms or wiring arm hoods: you always purchase them separately.
The 1756-OX8I needs a 1756-TBCH (Screw/Cage Clamp) or 1756-TB6SH (Spring clamp) wiring arm. These come with a hood and door assembly that slides over the top and the whole thing plugs into and locks onto the ControlLogix I/O module. You can get an extended depth hood if you use heavy-gauge wire.
Since it's eBay, it's possible that these were removed from service and they'll throw in the wiring arm, but if you get one without the wiring arm you are getting the same thing you'd get from the factory.
I'm trying to save a project as an L5X and I need to uncheck the "Encode Source Protected Content" checkbox, but it's grayed out. How do I get...
946
Has anyone done this type of an application before or can point me in the right direction? Biomass is corn husk. it can be partially dried or...
1,765
Hello! How can I clear (delete, write zeros, false) a DB in TIA V11 SP2 Upd5, CPU 1214C, if the size of the DB is NOT known? More exactly I...
4,668
Wondering about the possibility of disabling the [encrypt file content auto check box]. I'm running Factory Talk version 7.0 when I go to back up...
2,471
Dear bro, I'm using RsLogix Emulate 5000 ver 20.01 and FactoryTalk View Studio 7.0 with Windows 7 64-bit Pro. And I got some display errors like...
4,800
