Control Builder Plus Problem
dobidust
Sep 2011
Middlesbrough
44
Hi all I have a problem when trying to simulate even just small bits of code in CoDeSys software in Control builder Plus. I can toggle bits from true to false and vice versa but the signal does not flow through the rungs of code. For example if I put 2 inputs into an AND block and then toggle the two inputs on then output does not trigger. I have tried in many different combinations but still no joy could any body shed any light on this problem ?
Regards
Drew
Are you sure the simulator is in run mode?
The other thing that comes to my mind is that when you double click on a variable to change its value, you then have to press ctrl+F7 to apply the changes.
Regards
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
118
Does anyone have ABB Control Builder Plus V2.3 install ? i don't want Automation builder which replaces it, i would like the older version...
1,679
Hello everybody, I am working on a project where I will update some functionality in older machine. I have to use ABB Control Builder M...
1,068
Hello Guys i'm new here i would know if it is possible that you could help me out with this issue
4,266
Hi, does anyone know where i can download this software i am in urgent need of it as i need it to complete my school assignments. only the...
5,384
