Control/Compact Logix PLC5/SLC Mapping Function
cjh
Mar 2003
Cumming, GA
235
Is there a trick to get this function to work with the Binary Data Type?
I can get the Integer and Float data type to work with no problem, but I get errors when I try to map over the Binary Data Type?
I would assume that this work since RS Logix 5K let's me map down to file number 3 (Actually lets me map down to 1).
I use an array of INT's after playing with a BOOLEAN array and getting weird mapping.
When you think of it, using something like b3/49 (in SLC land) is just a shortcut way of b3:3/1
Dave makes a good point. One other thing to consider, is why are you even trying to map bools (B3 like binaries)?
Just map an integer file, and access it the normal way for integers; ie: N35:15/01.
It should end up being much more efficient.
Strange...it's working on my Compact Logix this morning. When I tried it on a Control Logix yesterday, I'm sure it didn't work. I will try again later today.
I'm trying to convert over a project that was previously created for a SLC 5/03 and I'm trying to change as little as possible.
Probably true. Efficiency on performance is not a concern in this setup.
Thanks for the replies.
IIRC, when I first tried it, it seemed to work, but for only maybe 8 bits at a time, skipping 8, then working for the next 8. Or something like that. It was 3 years ago using v11.
What I endded up with was an INT array, named B3, so using B3[xx].yy mapped directly to the same addressing (B3:xx/yy) in my CTC HMI.
So if you use it that way, you just can't use B3/ZZZZ type addressing and you can use the same addresses as in the SLC 5/03.
263
Hello, I’m looking to control a bipolar stepper motor using a stepper motor drive and a compact Logix PLC. Can anyone point me to how to program...
3,653
I want to network (ethernet) Control Logix with two Compact Logix; is that possible?
2,761
Hello, For my general information and knowledge, how is querying and storing data from a AB PLC (Compact or Control Logix) typically...
7,418
Dear all, i am using compact logix l18er and control logix l63 i want to use message instruction in between this to i am not getting proper...
3,824
