Control Logix tags for Wonderware
brett93304
Apr 2006
California
Let’s say you were devolving a new program for a Control Logix Processor, and you knew this PLC would be monitored/controlled form a Wonderware work station, how would you go about grouping/creating your tags to make polling them in Wonderware easer?
Would it be worth the time to create an array/block of all the DATA and poll just that array/block?
Thank you,
Brett
There are a lot of considerations but I am learning to love the user defined tags and if you address the alpha numerically your implimentation into the ww tag dictionary is very quick. e.g.
tag type pump
pump1.start_pb
pump1.start_il
pump1.stop_pb
pump1.stop_il
pump1.alarm_timer
when you enter
pump1.start_pb
then hit new tag it automatically increases the name to
pump2.start_pb
so you can really save time here.
Yes, using UDDTs and arrays with ControlLogix processors enhances data transfer efficieny with a well considered layout. You get much extra benefit if this helps you write a simpler/cleaner program in RSLogix 5000.
So I've been getting around something that is confusing me. Attached are my notes. I have a tag that I can change in an Panelview32. I found...
3,502
Hello and thank you for taking the time to view my post! First of all, I've attached an image as reference. What I am trying to accomplish is...
4,343
Hello. I installed 7 Yaskawa V1000 Drives along with the Yaskawa SI-EN3 comms cards. I was able to follow the steps from the Yaskawa web site when...
5,871
Is there an easy way to move Program Tags to Control Tags. I know I can export and import tags, but can you import exported program tags into...
13,573
hi everybody i am having tags and comments in excel i just want to import them into my control logix program.i have rename the file type as .csv...
2,936
