Control Servo Motor With PIC
Nauman
Jul 2004
Karachi , Naval Colony
I want to control 5 servo motor with PIC16F877 and stand alone (Basiclly the design just need start all the servo when power on)...which only will rotate 70 to 120 degree then go back to where it start rotate for each servo motor and all the servo moving at same time. Below is the list of servo motor i using:
1)Three ,
Hitec HS-55 Servo(rotate 100,110,120 degree) //http://www.hobbyhorse.com/hitec_hs55.shtml
2)One ,
HS-6975HB servo(rotate 70 degree) //http://www.robotstore.com/store/product.asp?pid=947&catid=1638
3)One ,
HS-65HB servo(rotate 80 degree) //http://www.imagesco.com/catalog/motors/HS-65HB.html
hope u all can help me,thk alot.
Hi; Normally if someone talks about SERVO, its refer to such a motor control system in which a motor, having permanent magnet on rooter, or a DC...
2,418
Hi all, Got an application where the customer is looking to use a servo motor, purely because of the very wide speed range required for different...
3,704
Hi guys, How do you control the servo motor using Omron driver and GX developer?
1,508
I am working on a project to control servo motor through servo drive and Omron CP1E N30 PLC . It was previously programmed by someone and now we...
1,151
Just the other day I saw a hydraulic forming press that didn't seem to have a pressure relief valve. It had a Servo motor connected to a pump that...
2,112
