Controller Logs to HMI
The Plc Kid
Feb 2009
Macon, Georgia
3,233
Is there a way to bring the controler log of a L61 out to a FT View SE App?
In the manual you can use a message instruction to push it to the compact flash card but We want to display it on the maintenance screen of the SE app.
This way we don't have to login to the Assest center client each time.
I'm trying to keep a record of controller logs without writing to an SD card. Is there a way to keep a record of the controller logs inside the...
1,077
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
56
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
45
176
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
54
