Controller that operates below zero celsius
klikopc
Jun 2009
Ptuj
64
Can you guys name me a couple of controllers that operate to about -20 Celsius?
I need one to work in outside conditions for the entire year!
which one would you recommend?
Matic
An insulated panel with a panel heater can be a good choice to keep any controller running through the cold winter months.
That would work, but i need a guarantee that it will work at any time, even if power goes out for a day and the controller gets to below zero temperatures, like for example in a car. It has to start up without any problems once power comes back and is not yet heated enough!
For what it is worth, take a look at Schneider Twido Extreme.
I never used them but the specs may meet you needs. Operation spec from -40C to 110C. It looks like it is made for heavy machinery / construction vehicle use so I do not know if it will work on your app. No idea how much this costs either.
I think one of the other EEs here was looking to use a small micro GE Fanuc once that supposedly had the op. specs down to -20C. I don't know what model # but it might be worth a look at their site.
Hello! If someone can help me with the following problem. I can't change the phone number. Do I really need the interface (AL-232CAB - Programming...
43
I have Woodward Controller EASYGEN-3500XT and Phoenixcontact make IO CAN-CUPLER part no: 2702230, Analog Input card: 2861412, Analog Output Card ...
36
155
Everything was working fine, but suddenly CPU went into error mode, and the ERR and TER LEDs lit up. Now I can't download or connect with the PLC...
45
I am running CCW 13 trying to upload to a micro 820 vers.12 I get an output message OPC server is unable to load project controller. Please help!
241
