controlling water level in a tank
Ali Sayghe
Sep 2012
Tempe
I am trying to build a project for controlling water level in a tank using PLC,3 level sensor, water pump, and electrical valve and i need help any one teach me how i can build up my project and i am willing to pay for the help
Edit: Start by making a sketch of where the various components will be in relation to the tank...
Then continue by writing yourself a specification of how you want it to work.
First part of the spec. will be whether you want the tank level control to be completely autonomous, or do you want it to be started and stopped, in which case you will need some sort of "Operator Interface" - which could of course just be some push-buttons and lamps.
Then write the spec. for the sequence of filling a tank... keep each statement simple, e.g.
If Low-level probe is uncovered, open valve X to fill tank.
etc.
Coding from a well-written description of the process is easier than deciding the process on larger systems.
(y)(y)
Ali, i had a problem with a tank that kept overflowing that had mechanical floats. Not good. Rust, and contaminents in the water was always causing problems. I found a capacitive proximity switch from MSC company, normally open, and installed it to verify the water level of the tank. When the water level got below the prox, it would turn on a valve to fill. I programmed a timer so that it would fill for 30 seconds, then shut off. 300 gallon tank, yours may be different. I programmed a timer, keep it on for 30 seconds, then shut off. If not filled, then another 20 seconds, so on so forth. This prox worked great and has been in use for about 2 years. Also, it is grease proof, only liquid will activate it. MSC part number 54049762 @ $221. Well worth it. Check it out
Tony
Another concern to be aware of .......... You should limit the number of cycles that the pump makes.
Starting and stopping a pump is the worst case for the motor, high current on starts and heat soak on stops.
You were not specific about your level sensor,if you are using for example an ultrasonic sensor, scale your analog input to reflect the values of your sensor in relation to tank capacity and use high and low limits to control operation of your valve or pump. I am attaching a ladder diagram which is using a sensor for level control; the scenario is different in that it is using a floodgate as opposed to a valve or pump but the logic is similar and should give you some insight.
I currently have a pressure switch and a back pressure regulator. I am planning to replace the regulator with an E/P electronic-pneumatic...
4,408
Hi, This is a control problem. I am currently planning to control temperature of water by mixing hot and cold water through a three way valve...
3,764
Hi all, We have a large watertank and from that large watertank we try to supply the water to our watertreatment as constant as possible. But we...
1,507
I have been tasked to maintain 80 PSI water pressure in a 6 ingh pipe using two 40 HP pumps with two Powerflex 700 VFDs in and existing...
4,177
Hello to all, in attachment, you can find one problem example of maintaining water pressure in pipes. I need to hear your advices and opinions on...
2,385
