taylor1982
Hello,
I have to communicate with a KUKA robot (Type KRC4 with EthernetIP Interface). For that I use the Generic Ethernet Module with the settings
Input instance = 1
Output instance = 2
Config instance = 3
Input = 20 (8-bit)
Output = 52 (8-bit)
DataType SINT
I successfully integrated a communication between a ControlLogic and a KUKA KRC2 robot three years ago. In this project I used the settings above.
Now with the KRC4 we don´t get a successfull connection. We always get the error code "16#0315 - Connection Request Error: Invalid segment type".
I´m not sure if the configuration on the robot side is OK.
Does anybody know with settings particulary which instances are needed on the PLC side? My PLC is a 1756-L72.
Thanks very much for answers.
Input instance = 1
Output instance = 2
Config instance = 3
Input = 20 (8-bit)
Output = 52 (8-bit)
DataType SINT
