ControlLogix CPU Usage Varying
aufisherman
Apr 2016
Pensacola
Hello,
I am trying to perform the new Rockwell PlantPAx Verification checklist thing.
If execution time is not varying on my tasks, but the CPU usage is varying greatly (20% to 70%) what could be the culprit?
I see that there is an issue, but I cannot find any information on specifically what to look for inside my routines to identify the source of this varying cpu usage.
Any thoughts?
Thanks!
Are you using a lot of timed tasks? CPU usage could be low when not doing an active task, but high when doing so? Not sure how long of a time that "usage" is averaged over.
This is not batch. It is a continuous process and we are using periodic tasks. My 1000ms task that has all of IO and regulatory control FBDs is the one that is varying from 50-95% cpu usage while scan time varys between 170,000-220,000 microseconds.
They are periodic tasks. The culprit is a 1000ms periodic task that has all the IO and regulatory control FBDs. The scan time will hover between 170,000-220,000 microseconds. Sometimes the scan time will stay the same while the CPU usage just climbs from 50% to 99%
Haha. This is one of the only "full DCS" implementations of ControlLogix that I have really worked on. The controllers are being used for process control.
The process library objects that are used for a PlantPAx implementation are very heavy on useless stuff you never need so a lot of overhead.
That's a brutal scan time, but makes sense with a big PAx program. Just curious, what processor are you running and about how much I/O?
Hi all I am having problem with a L75 CPU which running 100 % CPU Usage. It doesn't have any Continuous Task and 50% of the CPU is taking by...
1,762
I would like to Read the CPU Usage % information like the Task Monitor tool provides from one ControlLogix to another via a CIP Message. Comms...
5,909
I am working on a project that requires an additional remote rack (say about 150 i/o points) on a L73 redundancy system with about 900 i/o points...
867
1) I am currently trying to integrate a Prosoft MVI56E-MCM Module into a 1756-L61 CONTROLLOGIX5561 that is a redundant system (CPU is redundant...
3,424
So this is a weird issue and its really a stretch to guess what is happening. We have what is known as a lug chain, which is basically a...
2,244
