ControlLogix L73 (RSLogix5000): Mode Decoder?
Dec 2016
Southeast
134
This app has multiple modes which control different combinations of pumps, valves, instruments, etc. I'd like to do this using bit control. What's the best way? Is there a built-in programmable "ModeDecoder" I can use, or do I have to code it all out in brutalized logic?
Hint ...
CLR ModeBits
OTE ModeBits.[ModeNumber]
Indirect Addressing
If brute force logic is clearer, then I use brute force logic.
I'd rather have a set of a dozen rungs that literally looked like a truth table than a clever indirect addressing rung.
Each to their own, Ken. I don't think indirect addressing is "clever", nor is it difficult to understand.
Most Bubbas worth employing understand a number inside square brackets that specify an array element, so it's not a great leap for them to understand how a tag name or an expression inside the brackets can be evaluated down to the array element number.
If indirection allows me to write one rung of code instead of n rungs of code, then I'll use, and teach, the least "expensive" method, in terms of memory usage, and execution time.
In another thread, the OP posted an application that decodes a two-digit thumbwheel switch using eight inputs.... it was done "brute-force" with 20 rungs of code, 10 for each decade, then the 2 partial results had to be added together to form the result. I resisted the temptation to shout FRD !
Where can I find information on how to implement redundant Allen Bradley Controllers. We have this critical app here that ran as a single PLC for...
2,760
Hello! I'm struggling communicating a L320ER PLC through MSG Instructions, specifically I'm struggling with communication paths, I tried...
1,338
I have a project I want to get a L73 ControlLogix CPU for. I have a rack, power supply and a few cards, so I need a CPU, EN2T & some cards. This...
1,609
Hi there, Can I only force outputs to stay Energized/On or De-energized/Off or does this work within a ladder logic program on temporary coils too...
1,780
Hi, I am curious to know what will happen to a Running 1756 ControlLogix L73 controller if the keyswitch is changed from Remote Run to Program...
1,620
