ControlLogix to C# Communication Options
Jun 2005
54
Dear Experts,
For one of our projects, I am trying to communicate L73/ L75 CPU with C# application on Ethernet. One of the options I found from Pyramid Solutions, for which hardware module is required by Pyramid.
Trying to find out some other options. Has any one used C# application with CLogix CPU over Ethernet? Request you to kindly suggest me possible options for this communication.
Appreciate all your suggestions in advance !
If you are using Visual Studio Professional, then you can use AdvancedHMI by adding a C# project to the solution and adding a reference to the AdvancedHMI drivers project. You can then use the drivers via code.
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
319
Read and write the Tags direct using pycomm3 and LogixDriver. Just in case anybody wanted to know. Here's a sample: from pycomm3 import...
808
I have a DeltaV DCS system we are putting together and will pull data from a Allen Bradley Control Logix PLC. I am not sure how that communication...
1,143
Hello PLC folks, I am using ControlLogix L74 v21 PLC and FTView Studio SE v10 in my current project. I have one engineering PC in which I hold...
1,424
Hello Experts, We have a Control logic chassis with an EN2T module for the local Panel View HMI module. Now the client asked for a redundant...
2,194
