Controllogix, Versa View, and the Kep server.
Bitmore
Dec 2003
Automation Alley, Oakland County, Michigan
477
Hello all, just a cheap old cheat note.
I ran into the same problem most of us have seen, that field device talks Modbus RTU and I need more data, but I have an Allen Bradley Controllogix PLC. I don't have the money to buy an expensive interface module. Alas all is not lost with the Kep server widely available and my AB HMI. That is, you may use other type HMI's as long as they have the same type of serial server capabilities.
No special hardware modules needed for the protocol conversion, set up a timer bit to envoke a MACRO on the HMI, the KEP server querries the device, and tags are updated! SWEET! Just some basic signal conversion hardware (29.95)!
just a....
bitmore
I'm just curious.
How much a converter module would cost to justify the price of two KEPWare drivers (something around $800 list each)? Add to it the price of a modestly-fit PC (not everyone has an old one to use). And should not forget the above mentioned $29.95 for the hardware.
Seriously, is that coverter made of pure gold?
I have 5 systems that include a ControlLogix PLC and a Micrologix 1400 PLC. I need to connect these two via ethernet. I want to have two inputs on...
1,788
100
Why does the controllogix redundancy modules use a single mode fiber vs multimode fiber?
105
Hello, I have two 16 point input cards and 1 16 point output card showing module faulted on my IO tree in Logix Designer. The fault code is...
233
Hello, My associate and I are trying to sync up two ControlLogix racks (7-slot chassis) with identical modules. We are able to see the secondary...
220
