Controllogix version of 1763-NC01
Alan Case
Apr 2002
Wagga Wagga
1,268
Hi.
I need to connect the serial port of a ControlLogix PLC (DB9) to a serial port of a Kingfisher telemetry unit (RJ45 style plug) It is easy to do with a micrologix unit as I can use the 1763-NC01 unit. Does Rockwell make a DB9 breakout cable as such or are there adaptors/cables to do this function.
Regards Alan Case
I've done this by just cutting the end off a serial cable and putting a rj45 connector on.
(note: not to connect to a kingfisher unit, i was talking to a perle)
The 1763-NC01 breaks our the RS485 connections from the Micrologix 8 pin DIN port. The 9 pin serial connection on the ControlLogix does not have RS485 pins. Does the Kingfisher unit use RS232 or RS485? Also - what protocol will you be using? The Micrologix have Modbus RTU available. The ControlLogix do not have it natively.
I know there's the DTOS Function, but I have a value of "35" that is really "0035", and that's how I want it converted. Looks like the function...
1,524
Hello, I am currently converting a project from PLC5 to ControlLogix. I have migrated the program from Logix5 to Logix5000 and any Block Transfer...
3,359
We have Factorytalk View SE distributed project running version 7. I am trying to connect a 1756-L81E processor to the project using RSLinx...
4,077
I am struggling with the conversion of the program used for the 1403-nsc smart card for Allen Bradley's power monitors. We are upgrading an entire...
3,530
Hi all, I have used your forum a lot in the past for helpful hints, but I could not find anything on this question. I have a project where I am...
2,865
