Conversion from GE FANUC 90-30 series to Siemens S7
My answer in post #2 applies to conversion of GE 90-30 hardware to any of the Siemens S7 PLCs. It also applies to conversion of the ladder logic in the 90-30 to a program that will run on that Siemens S7 platform.
The question about a utility to convert from brand X to brand Y has been asked dozens of times. Ask yourself this. What would be the incentive for anyone to create such a utility? Do you think that any PLC vendor could generate enough revenue from it to cover the developments costs? The PLC vendors don't seem to think so since they haven't developed any.
The fundamental difficulty in creating a conversion utility is this. Without some understanding of the process controlled by the PLC, translating individual rungs of logic is somewhat akin to translating a document by looking up individual words in a dictionary.
The closest thing there is today is the ability of some to have Import/Export of 'xml' but that is not done "Equally" either.
We have a client whose previous control system was using lm90 logic on 90/70 system. Once 90/70 CPU was controlling other racks using Genius bus...
1,848
Hi.I am new to the GE Fanuc plc. I was able to work out simple programming examples so that i get a hold over it.Now,i am doing a project where i...
2,936
Hi everyone. I'm communicating with a remote gas sensor through Modbus from a GE Fanuc 90-30 as a master. I'm able to communicate with the...
4,992
I have a machine which is undergoing upgradation. As part of the process two SEW drives are being replaced., existing Gen B with new Gen C. The...
229
Currently I’m using ESA model VT155W0000 HMI and it’s communicate with Fanuc PLC. Can any one suggest can I convert ESA model to EXOR HMI eSMART07M
109
