Conversion of PLC5/250 to CLX
Feb 2005
Calgary, Alberta
68
We have one PLC which is PLC-5/250. We have its backup code. We need to upgrade it to ControlLogix. Is there any way to convert this code into ControlLogix code? Also, I do not know how to open this file (As it seems to be having with some quite old software - older than AB 6200.).
If anybody knows about this, please help me out in this. I would appreciate the detailed reply.
Thanks in advance.
Regards,
--Rahul.
rahulkumardave said:
Thanks in advance.
Regards,
--Rahul.
Hopefully a hard copy program printout is available.
I've done a few of these conversions the old fashioned way, typing by hand. Not all instructions convert properly and the way the 250's memory and program areas are layed out can be very confusing.
You can use Excel to import and manipulate the I/O tags into a format Clgx can understand, and import, but other than that I recommend type it in yourself
Ian
There's a consultant named Pete Jack in Seattle who has developed PLC-5/250 to ControlLogix conversion tools that he uses in his automation consulting business. I think that hiring him to perform the conversion will be more cost-effective and faster than getting software tools and learning the old controller's architecture yourself. I'll send you his e-mail address via PM.
I've had Pete do a conversion for me from 5/250 to CLX. It worked fairly well, but there are some instructions that do NOT convert at all - and a lot of things that do not convert nicely. It gives you a great starting point, but, at least in my program, still left alot of work.
When doing a conversion like this, I always ask if a straight conversion is desired, or if it would be better to just start over. PLCs have a lot more capability today than they had 20+ years ago. My experience is that it's typically better to just start over and rewrite the code than to convert it.
When you do a conversion, you convert the existing problems/deficiencies AND introduce a whole new set of issues...
Also, the PLC5/250 had its own special version of 6200 software.
It certainy does leave a lot of work. I inherited one of these conversions and I discovered one major flaw.
The conversion creates an individual tag for all booleans where a simple DINT alias would have sufficed. Example, the conversion created an individual tag for Output_30_bit_00, Output_30_bit_01, etc. I just created 1 DINT OUTPUT30 and aliased that tag with the output. Done the same for Ins,Timer and bits and by doing this the program size shrunk from 1.3Meg to 800K. By doing this I freed up enough memory in the PLC to resolve MSG timeout errors that occured with Basic Modules.
As OZEE stated, the conversion works, but there is still quite a bit of work to do.
I'll second that.
I've converted 1774 to PLC3; PLC2 to PLC5; PLC5 to CLX; PLC5/250 to SofLogix 5; Wizdom Paradym to SoftLogix 5.
I use the original program as a reference and an aid in understanding the machine / process - then re-implement the logic for the new platform. I usually manage to eliminate a few problems and add some beneficial features in the process.
When it comes time to commission the new system, I know how it works. If I had an automated conversion or a straight rung for rung conversion done manually, I would spend a lot of time chasing my tail and going through the process of understanding the process at the wrong end of the project.
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
2,011
Hey everyone, Just a question regarding the conversion of FAL element addressing between a PLC-5 and Logix5000-series processor. In the...
1,628
I have a box erecting machine that uses a PLC5/20 and SFC currently. I need to convert the equipment to run in its new home which will be...
1,337
I have experience with converting PLC5 to Logix but this system has two PLC5s, one of which is used in adaptor mode. I'm wondering if someone...
2,543
Hello, I am doing a PLC5 to 1756 L81 conversion. I have an issue with what looks like an indexed array bit in the PLC 5 that I am unsure of how...
1,281
