Convert a STP File to DWG
Bullzi
Jun 2012
Colorado
1,530
Hi everyone,
I have downloaded a .stp file for a item I need to put into a panel but since I only have AutoCAD LT it wont import .stp files. Guess that is why it cost less (n)
Can someone that has a full version of AutoCAD convert this over to a .dwg so I can use it in LT?
Thanks for the help!!
I am trying to add a file to a panel layout in Autocad. The file is in .stp format and is a model of a powerflex70 drive. I have already tried...
6,097
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
92
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
319
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,399
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
536
