Convert Decimal to Fractions
Just FYI: If you use 32nds, Then .99/.3125=31.68 which the PLC will round up to 32.
If you use 64ths then .99/.015625=63.36 which would show as 63/64
If you use the code example I offered then add one additional rung and use bit.5 to divide by 32
Hi all! looking for help converting an 8 bit word SINT tag into decimal. I have an IFM SBN246 flow sensor wired in my controller (L310ER) and it...
2,174
Hey All, i have been fortunate enough to play around with an Applied Motion Products Servo Drive SV200 with 100 watt/ 24vdc congif. I managed...
1,887
Hey all, Here's a tricky decimal to binary conversion project I could use some help with: In my RSLogix 5000 application, I have a "checklist"...
3,074
Hey all, I've reviewed many threads regarding converting one data type to another and I have something I'm working on that I'm stumped on and...
5,921
I'm working with SLC 500 Data File. I have a few numbers like 8.313452e+07 . I forget , how do you convert these numbers . Thanks so much.
2,509
