Wondering how to convert this number to decimal 8.313452e+07
Rob S.
Sep 2008
Maryland
739
I'm working with SLC 500 Data File. I have a few numbers like 8.313452e+07 . I forget , how do you convert these numbers .
Thanks so much.
It's scientific notation. Move the decimal point "+07" places to the right.
83134520.0
EDIT: I had it backerdz at first. The "+" means make it bigger (move the decimal to the right). If it were e-07, it would mean make it littler by moving the decimal place to the left seven places...
Related to this previous post.......
I have a customer that has a data file with product codes. I would like to put them on a display I am working on. I have the following issue related to scientific notation concerning the "e" in this number. 8.313083e+07.
This is what I have........
Customers product sheet. 83130834
SLC 500 Data File F41:40. 8.313083e+07
FactoryTalk View Numeric Display. 83130832 ( Direct connection to F41:40 )
Why would this not come out to 83130834 , and what does the "e" have to do with it ?
Thanks so much.
Floating point is not a good choice for product numbers. Floating point rounds the number, only a certain number of digits will be maintained accurately. This is fine for calculations, bad for identification numbers. Since you are in a SLC500, you could use two integers 9999 + 9999 to get 8 digits reliably. Or, you could use a string (my preference). However, if there are a lot of codes, strings will chew up a lot of memory.
Thanks . What does the "e" actually stand for ? I understand the 7 means to move the decimal point over 7 spaces. But what about the "e" ?
Thanks in advance.
One more question concerning this. Can you use a MOV to move a floating number ( F41:4 example ) into a integer ( N7:65 example ) ?
Yes - if the integer portion of the float is within the range of the integer (-32768 up to + 32767). You will only get the integer portion. Check on rounding.
Good Morning , I think I have upper management convinced to begin replacing our SLC 500 PLC's . It is incredible the increase in price on SLC...
2,072
Hey all, I've recently been asked to help spec some SCADAPack controllers for a project. I'm specifically being asked if the E series...
8,026
Hi I just were sitting in my desk and was wondering if by any chance any of you worked for Eaton in Aurora or Berea in Ohio. Aurora was full of...
1,635
Wondering how to "defeat" the left hand most timer in Logixpro I/O simulator Wondering if any one can help answer the attached two questions...
2,210
Hi guys! Newbie question or you. I'm just finishing up a diploma in Industrial Automation. But I am job hunting and I'd some clarification. We...
2,168
