Wondering how to "defeat" the left hand most timer in Logixpro I/O simulator
adridas
Apr 2016
Maine
Wondering if any one can help answer the attached two questions.
I've already set a repeating timer that has the accumulated value of the timer displayed on BCD display, but now i'm having trouble figure out the next two questions.
Any hints or how tos would be apperciated!
Welcome to the forum!
The "Masked Move" the question refers to is the MVM instruction. Drop one of those into the code, select it, and press F1. Read through the help file on how it works and what it does - that should give you an idea of what your instructor is hinting toward. Have a crack at implementing it, and post back if you get stuck!
Thanks,
I have tried it out, but i'm really at a dead end on where to start with the MVM, i've attached it to the program but really not understanding how overcome the left hand thumbwheel with the MVM command.
Well, if I understand the question correctly, you've got four thumbwheel switches, each giving you a BCD value inside the PLC.
0000...9999
If the right-hand one is set to tenths of a second, then you can set any number from 000.0 to 999.9. You need to convert this from BCD to decimal, and move the value into your timer. My first tip is to revisit your logic slightly, and try to perform these operations in that order. You'll find it much simpler from there.
Once you've done that, you can approach the next part of the question: allow only values from 000.0 to 099.9. You want to block the first digit from having any effect. So, you need to strip out the data from that first thumbwheel, and move only the remaining three digits into your timer.
Two questions you can hopefully answer:
1. Should you strip the first digit out of the data BEFORE or AFTER you convert the BCD to decimal?
2. How might you use a MVM to move only the part of the data that you require, while masking the rest?
Good Morning , I think I have upper management convinced to begin replacing our SLC 500 PLC's . It is incredible the increase in price on SLC...
2,072
Hey all, I've recently been asked to help spec some SCADAPack controllers for a project. I'm specifically being asked if the E series...
8,026
Hi I just were sitting in my desk and was wondering if by any chance any of you worked for Eaton in Aurora or Berea in Ohio. Aurora was full of...
1,635
I'm working with SLC 500 Data File. I have a few numbers like 8.313452e+07 . I forget , how do you convert these numbers . Thanks so much.
2,508
Hi guys! Newbie question or you. I'm just finishing up a diploma in Industrial Automation. But I am job hunting and I'd some clarification. We...
2,167
