Convert from ControlLogix to SLC500 possible ?
JesperMP
Feb 2003
ᚴᚬᛒᛅᚾᚼᚬᚠᚾ
16,325
Hi all.
I have a working program from a compactlogix platform that I have to convert to an existing SLC500.
I am rewriting it manually at the moment.
I find that I cant even copy-and-paste between RSLogix5000 and RSLogix500. Even though they use similar instructions, I get only "unknow instruction" in RSLogix500.
I know that the chances are slim, but it never hurts to ask:
Is there a conversion utility to convert code from RSLogix5000 to RSLogix500 ?
It appears that I can highlight a complete rung in RSLogix5000, and then paste it to RSLogix500.
I have to highlight the rung by the rung counter in the left side in the window.
At least that is a step in the right way.
The whole tag structure is completely different from the LG5K platform to the legacy products. I personally would not think that this is possible, not understand why one would want to accomplish this task in the first place.
kcarlen said:
.. not understand why one would want to accomplish this task in the first place.
Because we have new wellworking control with a CompactLogix that we want to implement in an existing SLC500.
I can imagine that a conversion tool can do 90% of the job. Even with the different memory structure, the user could be prompted for how he would like to have it converted.
But I can imagine that there is no economical incentive for rockwell to create such a tool.
How is the correct way to convert a Controllogix program from version 20.11 to version 30? I have already flashed the processor to version 30 but...
2,697
Jees... Continuing from this thread... http://www.plctalk.net/qanda/showthread.php?t=85341 I now have the correct pressure in Torr and mBar...
24
7,433
I have a Panelview 1000. Originally its was communicating to a PLC5. I replaced the PLC5 with Controllogix. I have converted the PLC logic to...
19
10,371
2,409
Hi All, For some reason, I had to clear the recoverable major error in the fault hander routine and record the fault for history check, The...
3,383
