sarahc Member S Join Date Oct 2005 Location Waikato, NZ Posts 22 May 3, 2010 #1 Hi all, does anyone know where to find an app to convert FIX32 GDB database files to CSV and vice versa?
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 May 3, 2010 #2 sarahc said: Hi all, does anyone know where to find an app to convert FIX32 GDB database files to CSV and vice versa? Click to expand... Use excel to open the file then adjust it to make it look good. Then save that to a CSV file.
sarahc Member OP S Join Date Oct 2005 Location Waikato, NZ Posts 22 May 3, 2010 #3 Opened in XL. Yuck! Found this post http://www.plctalk.net/qanda/showthread.php?t=36556 with download for GDB_Make utility. Much better result. Cheers!
Mickey Lifetime Supporting Member Join Date May 2003 Location Palmdale,Ca Posts 10,659 May 3, 2010 #4 sarahc said: Opened in XL. Yuck! Found this post http://www.plctalk.net/qanda/showthread.php?t=36556 with download for GDB_Make utility. Much better result. Cheers! Click to expand... Nice find. I didn't know that existed.
Nukosan Member N Join Date Jan 2011 Location Southampton Posts 13 Aug 2, 2011 #5 Hi Guys, I'm using that GDB2CSV, and I found a problem: If the database contains PMP, TNK, VLV or other blocks (added later on to Fix) it fails to export the whole file. Anybody has a solution for this without fighting 10hrs with excel? Cheers G.
