Convert Modbus to CIP help
BillRobinson
Oct 2006
Sydney, Nova Scotia
185
Need a little help here,
I need to poll a radio/modem over Allen-Bradley Ehernet/IP. The existing radio/modem is geared up Modbus. Anybody know of some device that can convert Modbus to CIP? I know I can put a Modbus card in the control-logix chassis but I rather not do that because of space in the rack. Is there a way i can poll through the Ethernet card?
Tell us more about the "radio/modem". Is this an "Ethernet Radio Modem" or is it a serial modem with a Modbus RTU serial device connected on the other end ?
The Digi One IAP is the best device I've found for translation between A-B Ethernet protocols and Modbus RTU.
Assuming that the radio modem talks Modbus RTU I would suggest a solution that I have used widely and absolutely love. It is the wonderful little Micrologix 1100. I can write pages on the advantages of using the MLogix 1100 for ModbusRTU - EthI/P conversion, but I will mention below a few points just to get you a brief idea.
- MLogix 1100 has a built in COM port which when used with 1763-NC01 cable talks Modbus RTU Master or Slave without any problems.
- MLogix 1100 has a built in Ethernet I/P port which can be used for peer-to-peer communication with any other AB PLC.
- Using an RSLinx ethernet driver, an OPC topic can be created that serves out the entire data table of the MLogix 1100 over OPC for use in supervisory software.
- Apart from the communications capabilities, the MLogix 1100 has available on board analog and digital I/O in various configurations.
- The MLogix 1100 also has a little LCD display that can greatly help in troubleshooting.
The list goes on...
I have some standard example programs that demonstrate Modbus - EthI/P conversion using the MLogix 1100. Let me know if you are interested...
I have tried using the DigiONE IAP for the same solution but have come across some serious issues with its speed and reliability. I do not trust it at all.
Hello guys, I used modscan32 before to read data using TCPIP based on given IP Address, Device ID and etc. The data I used to read in modscan32...
19
4,134
Hello, First, please excuse my question I am new to Modbus. I have a CX-5140 control unit from Beckhoff and an instrumentation device that...
3,127
Found an awesome point of sale for $500. It sends an ascii string when a product is sold. Need to convert this into a number between 0 and 255 or...
2,278
I need a good idea to solve a small task. My customer bought a measuring device where the measurement is collected by a controller from a...
3,248
Hi All Using RSlogix 5k v.15 modbus master sample code. plc(master) is connected to modbus device(slave). If i use function code 1 to read...
3,036
