A SSR MUST be fed with a PWM, you can not use an analog signal for this, as it means all rest energy must be taken by the transistor.
even a toy train uses PWM so a valve can do the same.
and the 12 Volt is no issue as you should put the transistor just above GND in the line.
or use a L298N
or use a L298N
