Convert RS232 to any SCADA supported protocol
SCADA_student
May 2012
Mannheim
Hey guys, I am looking for a solution and running against walls since weeks...
I have to connect a meterological station with ABB microSCADA (Sys600) as part of a student project at my university.
The met. Station is sending every 10 seconds a datapackage <stx><lf>yymmddhhmmss;<sp><sp><sp>[measurand1];<sp><sp><sp>[measurand2];<sp><sp><sp>[measurandN];<sp><etx>[bcc1][bcc2][bcc3]<cr> via RS232 to the SCADA-Server. The problem is, I cannot find a system object where I can specify the inputstream (byte-position of measurands or measurand seperators or whatever). I've found the line object "SPA" that uses the RS232 interface (COM port, baud rate, etc), but I have no idea how I should specify the incoming datapackages. It seems, there no one-way communication designed for.
Now I think, I have to convert the datapackages into something useful for SCADA (i.e. MODBUS), but I can't find an easy-to-use tool to do this.
Hope you can help.
Thanks a lot for support!!
Robert
Take a look to kepware opc products. With their system you can write your own protocol to comunicate with your devices by OPC server.
HI ALL NICE TO MEAT YOU WE HOPE TO HELP ME ABOUT THIS Q I NEED TO FIND SOME ANSW ABOUT THIS TOPICE HOW TO CONVERT FROM RS232 TO PPI TO USE IT FOR...
2,583
Hi! What is the way to convert the code from the Codesys code to the Tia Portal? Regards, WK
39
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
122
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
381
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,625
