convert usb/rs485 for S7200 ?
you can use USB/Serial converter for this purpose... but make sure the converter should be the one which contains the circuit box in it, not that the simple one.
thank
but you indicates a commercial mounting
which must be purchased (prog C.i.)
I want to make a same assembly me as for the rs232 rs485
Don't waste your time as you will also require a driver for Windows. Go and buy one it will cost you a whole lot less. Dveleoping and testing the driver would cost you perhaps 20-50 times the cost of a commercial one - and then there is no gurantee it will work with your PLC. Even commercial ones do not work a lot of the time.
I have just used an Adam 4561 from Advantek. It was seamless from a computer running Vista and Omron PLCs from Omron CX-Programmer and Citect SCADA. The PLCs are quite old and I was expecting big problems. Workes straight out of the box.
The Adam is quite expensive but is isolated (a big advantage - no chance of ground loops blowing up serial and USB ports), powered from the USB port and has a terminal block connection for RS232/422/485. One at a time of course.
I am going to buy some more plug in terminal blocks and I have all my serial communications sorted in 1 simple unit that works.
ok, I post here my circuit which functions perfectly (convert rs232/rs485)
for those which want to make a simple connection with a cable and without convert,
I board also put the diagram of the cable alone
http://dl.free.fr/niWJn9Qoh
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
112
I have an application using an incremental encoder and then I convert it to degree (0-360) using calculation program. For a while, the calculation...
365
Hi all. Me again still learning Rockwell. So I'll be polling an INT data array from a Modbus SE power meter with a L82 (with a Modbus ProSoft in...
56
1,474
Hello, could someone kindly convert the attached RSP files that are currently used for SLC 5 PLC into PDF please
557
I'm trying to convert an RS Logix 500 fille when I open the 500 file and try to "save as" a .slc file, it does not allow it. It says " SLC library...
721
