Converting an RSS file for RSLogix5000 v21
Yisus
Aug 2015
Mexico
Hi, I tried to do it, I used "Traslate PLC-5/SLC 2.0" but i don´t know why it didn't work.
the program get stuck in the step four "Processor 'Bul.1761' is not supported"
I changed the processor but did not work...
Could you help me please?
All this is for a simulation, it's just a practice
Actually how to translate the program is the practice...
I need to learn how translate different program of RSLogix.
I'm not cheating if you're thinking that haha
There is the file
https://mega.nz/#!8p0HhYLJ!qdWNe7RRay4-03-SFRei2RQwAXKIXAzt8XqqnkmIQKs
I did it manually, but is completely wrong... I have some doubts
how can I use Time Base S:4 in RSlogix 5000 as I used it in Rslogix 500?
how can I use the OSR function in RSlogix 5000 as I used it in Rslogix 500?
why the binary output does not activate?
I still need to find the way to translate the program as I mentioned before
Thank for your time.
You do not have a Time Base word in RSLogix 5000. You'll have to create your own using a simple timer.
As for your OSR instruction, have a look at the ONS instruction in RSLogix 5000 - you may have to try to understand what the code is intended to do, and rewrite it slightly to make it a direct equivalent, but it should get you away.
Hello PLCs Forum, I am in a bit of a pickle and was hoping someone could offer me some help. I have a .rss file and just need to see the ladder...
122
I've finally gotten around to programming an AD Click PLC that's been sitting in my office for close to two years. The main reason I'm using it is...
4,652
Evening, Is it possible for anyone to convert my .RSS File to a PDF as I don't have the software available. Many Thanks!
2,424
Hi everyone... I'm trying to find a free converter online but without success. I want to convert an .rss file to pdf so i can review it on my home...
2,725
Hi Can someone please convert these into PDF, I don't have the full version. Cheers
1,388
