Converting my .mer to a .Apa
showshocka
Mar 2011
USA
510
I uploaded my .mer runtime file and I totally forgot how to convert it to a .apa file to view my tags. can Anyone help Please. Thank you in Advance.
Do you know what version your .MER is? If it's V5 or greater AND it was compiled allowing you to restore it, then you can restore it back to an editable application using the Application Manager.
If it's V4 or earlier, then it's a lot more involved process that will not give you the entire application back.
I think you mean *.MED file? - Machine Edition Development.
*.APA are APplication Archive files.
You restore *.MED files from either *.APA or *.MER files.
It must be a version 5.0 or newer *.MER file and the "Never allow conversion" option must not have been selected when the *.MER file was originally created.
You need to open Application Manager.
You can open it from Windows "Start/Programs/Rockwell Software/FactoryTalk View/Tools/Application Manager" or from within FactoryTalk View Studio under "Tools" at the top.
Then select "Restore runtime aplication" at the bottom and browse to your *.MER file. Give it a unique name and continue. It should decompile into the "HMI projects" folder and should then be available to select from the "New/Open Machine Edition Application" screen when you start FactoryTalk View Studio.
Regards,
George
dear all,really need help regarding this matter.. i got a mer file from my client. i already tried to restore it using application manager (FT...
41,823
The problem is, I need to some modifications in a PanelView plus 1000 aplication, I made the back up but when I try to convert my .mer flie to...
2,503
Hello Folks, I converted a mer file sucessfully to an apa file for an RS view ME application. Everything went according to plan following...
4,378
I have searched the forum for the instruction to do this conversion and found and (I think) properly followed the instuctions I found in previous...
9,455
I have a question about uploading a .mer file from a running touchscreen and then converting it to an .apa file that can be restored for use in...
10,946
