Conveyor PE and Motor Settings
emjr93
Feb 2015
Modesto, California
Hello all,
I am currently working on a small project for a conveyor system.
We have two different pack sizes (6 pack and 3 pack).
The program is set up for only one setting for motor speeds and photo eye delay timers.
Due to weight, some of the conveyor start delays and motor speeds need to be edited for the different pack size.
I'd like to save the settings operators enter for each within the program and have it change based on pack size selection, the code is as follows...
---------MOV
Source; Photo_EyeDelay[1]
Dest; Photo_EyeDelay1.PRE
The HMI writes directly to the source tag in the MOV function.
The PLC being used a CompactLogix.
Hi emjr93, my name is Chris, I worked for 20 years at Cadbury's here in the UK. What is the machine / equipment your looking at and is there any snippit of ladder logic I may assist with ?
The code is just a rung with a move function that takes the value entered on the HMI and moves it to the timers preset. I want to be able to save the values entered under 3 pack or 6 pack and have them automatically appear depending on the pack size selected on the HMI.
The boxes are being transported on this conveyor from a packaging machine to a palletizer.
I am not sure what your question is.
I usually use a "Recipe" to achieve what you described id the HMI is capable otherwise scripts (again if supported by HMI) and plc code to do the same.
Maybe something like this:
I tried something similar, the only issue is that when I transition between the two it would overwrite the last value and lose it. Therefore, the next time I select the opposite pack size, the value is essentially lost. I was thinking of using a COP function within the code.
Hello, I have a servo motor running a conveyor belt system. I do not have the exact circumference of the head pully and therefore I get some...
1,392
Hi Guys! Please, I'd like to know how Motor speed Control in Conveyor/Sortation Systems are Programmed/achieved for Factory and Warehouse...
2,071
Hello Everyone, I am very new to PLC programming and trying to learn PLC by myself. I found this awesome forum and would like to get some advice...
34
8,364
I am getting ready to put in a conveyor that must be on casters so it can be moved in order to maintenance the machine it is next to. Conveyor...
3,185
Hi There , I have a project in my college to detect products' color and refuse the one that i don't need and then sorting the accepted products...
1,455
