COP Sanity Check (solved)
JeremyM
May 2014
Dallas, Texas
1,233
I'm just trying to clear data for any type of String.
The following results in only the first character being zeroed:
Code:
tSINT := 0;
COP(tSINT, tStr.DATA[0], 82);
This works:
Code:
SIZE(tStr.DATA, 0, Size);
i := 0;
while i < Size do
   tStr.DATA[i] := 0;
i := i + 1;
end_while;
Figured it out. COP stops at the end of source data.
COP checks boundaries of source and destination for simple data types. It dies not do it for members of structures.
But try FLL(string_tag, 0, 1)- ladder, not sure about ST
Find a way to do a job instead of finding a reason not to do it.
Tools are never perfect and you have to use what is available in your toolbox today.
It should not, this is not C++, HMI should look for the LEN field if they want to follow Logix rules, but I recall that old FTView did the same long time ago.
But even in this case, all you need to do is to place 0 into DATA[0]
That's actually a fair point.
I've found in a few instances where the String type is used as a buffer space for comms, particularly ModbusTCP and Message paths.
My overall goal would be to prevent any mishap in those instances when simply zeroing .LEN and .DATA[0].
My go to for zeroing any structure was to keep an appropriately named zeroed copy of the structure and COPying it in to the target.
- The issue eventually faced is tracking down mismatched zero-structures when the original changes. With UDTs, not such a big deal, but Strings are evil in this regard.
-- I've almost scratched an itch lately to simply create a one-size String type from an AOI that has a variable length and fixed backing capacity of perhaps 256 bytes and bundles all the code operations you would typically perform upon it.
-- You could even use aliasing techniques to assign the contents to a Logix String type when needed.
--- How does FLL work, anyway?
--- How is it able to ascertain the number of bytes in which to populate zeros into any structure thrown at it, for example?
--- It appears to also generally accept any blob of bytes thrown at it - is there a way to pass-by-generic-reference (pointer-to-void) that I've missed all this time? Or cast the passed object as something else entirely?
---- In that vein, one curious thing is that with some UDTs and when they could be passed by reference into a Rockwell-defined AOI, a simple value of 0 can be substituted if you don't reference an instance of the type.
---- In the picture, Bus[1] is actually optional and 0 can be substituted.
---- How can we pull off the same thing with our own AOIs?
FLL fills whole structure, if this is UDT or String or Array of UDTs.
I use FFL all the time.
If you are using 5580/5380 PLCs, then you can simply do this:
MyString:='';
Overall, I know you want ST code. But from my experience, Ladder gives you much more flexible instruction set that allows better functionality.
Over the last few years I was trying to convert existent Ladder AOIs into the ST and had to stop because of luck of functions. FFL is just one of these.
This clarifies my statement - use tools that you have in your toolbox today instead of struggling with limited tools.
ST or LAD doesn't necessarily matter on their own - it's just that the remainder of the code written in some of our modules are vastly better suited for ST.
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
204
Hello all. I have a Danfoss VLT feeding an INT into my CpLX program. I need to concatenate the MSB and LSB for position. I used a COP, making sure...
644
Hello, I have been looking for a reference for the order that a UDT is copied in the COP instruction. More specifically - I have a set of code...
553
I'm having to make an AOI to use with a generic ethernet device because the manufacturer does not provide an AOP. I just want to do a sanity check...
1,265
We're converting a machine's control from CompactLogix to Micro800. It was originally going to be on a Micro850. However, because we've ended up...
1,594
