Copy or Fill
randy
Supporting Member
Apr 2002
158
For application purpose, what is the difference between a Fill instruction and a Copy instruction.
rmonroe
(In AB Terms, since not specified) Copy (CPY/CPS) copies source data of one or more elements to a destination, preserving the source and overwriting the destination.
Fill (FLL) takes a single value (either constant or from a memory location) and copies that single value to all specified parts of the destination which can be one or more elements long.
N7:0 = 10 N7:1 = 20 N7:2 = 30
N7:20 = 150 N7:21 = 13 N7:22 = 372
After CPY N7:0 N7:20 3, the table looks like this:
N7:20 = 10 N7:21 = 20 N7:22 = 30
After FLL 0 N7:20 3 the table looks like this:
N7:20 = 0 N7:21 = 0 N7:22 = 0
in general terms, FLL works with VALUES ... COP works with BIT PATTERNS ...
so ...
if you COP (Copy) from an INTEGER to a FLOAT (for example) then you can expect surprises with the results ...
Hello all, I have a basic question. I have an conveyor application where i need to copy data from location to another and then fill the previous...
3,755
113
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
94
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
179
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
1,018
