Copy Rungs From Rsl 5000 To Rsl 500
jimdi4
Aug 2004
108
I can copy rungs one by one and then change the addressing but is there a way to copy multiple rungs from Contrologix to a SLC 500?
Thanks!
I haven't found one yet.
The problem is that when you select multiple rungs, RSL5K copies them to the clipboard in Neutral Text mode ("XIC(Bit1)OTE(Bit2)") instead of the SLC-friendly ASCII mode. ("XIC Bit1 OTE Bit2")
You can try and selecting multple rungs (using the shift and/or control keys to assist), pasting them into Notepad, and then doing a search/replace:
open paren, close paren ==> space
semicolon ==> "EOR SOR "
left bracket ==> "BST "
right bracket ==> "BND "
You get into trouble with the comma. It's used both as a "Next branch" (NXB) and as a delimiter between numerical values in blocks ("COP(A,B,C)", and so could also go to space.
But if you're careful, you CAN do it.
Also, there's no need to search/replace on the tag names. If you have the SLC address programmed with a SYMBOL name that's the same as the existing CLX tag name, the logic will import without error. Just edit your Address/Symbol database ahead of time (a CSV import is great for this).
Good luck!
Allen,
I follow you on the whole copying to text, editing, replacing, etc but how do I reimport this now edited text file back into the SLC500 program?
I tried "selecting all" in notepad and tried "pasting" into the RSlogix 500 program but the paste function is not hilighted.
Are you re-importing this somehow?
How do you do it?
Highlight a rung, press Ctrl+A to enter ASCII edit mode, paste the whole clipboard onto one rung and press return.
That Import/Export abitlity you mentioned is for the database not the actual logic.
What was mentioned prior worked just fine.
aamof- If you ever get stuck with anything during the pasting of the ascii code you can just enter the logic as normal and do a cntrl A and see how the logic looks as an ascii file...
Thanks allot Alllen and NOP for all your help!!!! :D
and happy (or happy not) programming!!! :cool:
I know that the database can be exported, but I'm also sure that the SLC program files can be exported as well. But as I said, not being familiar with RSL5K, I would have to suspect that going the other way is possible to.
Hi All, As a precaution my company has been collecting copies all the HMI and PLC programs. I have recorded copies of most of our sites...
70
I have 2 7cp476 plcs. How can I copy one of them and install it somewhere else?
82
Hello Inside a FB, I´m trying to transfer a string from a DB to a IN_OUT var that was define as a UDT. The problem is that i can´t determine the...
153
Hi everyone I'm in a bit of a conundrum, I've been trying to get this HMI on our machine and I am unable to retrieve it. Device Delta Model...
920
Hi I have a Melsec FX1S-20MR, which has been programmed. I would like to copy the program to a new FX1S-20MR? What are the possible ways to do...
639
