timbo_uk
You are right about damaging the rotary valve, we had it once where (the usual) "somebody" hit the E-Stop on the panel and did a runner. The next thing we knew of it was that the "insides" had warped! PITA job to replace valve seals and reset the rotary section!
So I assume your initial logging checks plant running time, response time of RTO from "idle temp" to operational temp? You then study this info etc; go back in and add timers etc?
Will you be allowing (eg management) access to some sort of programming for the next weeks production times? How do you allow for a customers emergency Saturday morning production run to get a job out? That could be a potential scenario?
Do you add pulse counters on gas metering etc to cover your backside for companys that WILL say, your system saved us nothing!
Good luck with the business!
