CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet
JRW
Jun 2002
South Carolina
2,301
I have a S7400 414-2 DP fw5.3 with a CP443 6GK443-1EX30 fw3.0 and FM350-2 on profinet
The interface module is a 6ES7153-4BA00 fw 4.0 (ET200M interface module)
All the I/O in the rack function (and drives on the network) fine but the FM counters will not count and I get a system fault regarding I/O access errors with the FM's
The problem is with the CP because I can move the same configuration to a CPU with a built in PN port and it works fine (I move this rack to the on board PN port with the cpu)
I am using the latest PN blocks v2.x (that I know of) for the FM350-2 on profinet
Can someone please verify if the FM350-2 works in a CP443 6GK443-1EX30 ?
Or ANY S7400 CP
I really just need a confirmation that this will work or not- or you have a similar S7400 system working
I know this doesnt work on an S7300 and a CP
THANKS!
Since it’s profinet I’m using the pn blocks.
So those are sfb52/53 inside the counter blocks (the way I see it)
I couldn’t find any info if those are supported with a CP
You find anything in the CP manual?
sigmadelta
Those are great ideas.
My FM350-2 config software is V6.0 sp1 ( that's the latest I see)
I will check and update my IM153 if needed. I know its 4.x something but I don't know if its 4.0.3 (which is the latest)
I noticed the FM350-2 2AH00 firmware cannot be updated but the 2AH01 can be.
I tried both the 2AH00 and 2AH01 on site but the results were the same- but I didn't look at the firmware of the 2AH01 that I tried though.
I plan to be onsite next week to try this again
I appreciate your thoughts on this
I am troubleshooting the setup of UDP broadcast receiving on a CP443-1 CP card. The telegrams appear in WireShark with IP 192.168.1.255 Port 7551...
2,292
Hellow, I'm facing a weird problem with time sync since we've changed from summertime to wintertime. So now it's 12:38 pm in Belgium and the CPU...
1,875
2 CPU's Fiber connected on same rack etc out to a number of ET200s. Set up and running, happily falls over to the other PLC if one switched or th...
1,339
Hellow, I would like to build a MODBUS TCP connection between a Siemens CP443-1 (or a Siemens CP343-1) card and Visual Basic Application on...
12,603
Hi I have a system where essentially i am connecting an HMI via a switch to the CP443 card. I've set an IP address in the PLC end and an IP...
1,559
