CPM2A Omron PLC question
mraj2001
Jul 2009
Jabalpur
20
I have a CPM2A PLC setup for a machine. There is an rotary incremental encoder connected to the PLC at input 0.00 (A+ terminal of encoder) and at 0.01 (B+ terminal of encoder). When the encoder rotates I can see LED switching at these inputs. But when I connected my PC to PLC and look in the program but I am unable to see these inputs in ladder logic. Can you explain me how the pulses of encoder are counted in the program. Which instruction may be used
mraj2001
High-speed Counter Inputs
Inputs IN00000 through IN00002 can be used as high-speed counter inputs, as shown in the following table. The maximum count frequency
is 5 kHz in differential phase mode and 20 kHz in the other modes.
Input Function
Differential phase mode Pulse + direction input mode Up/down input mode Increment mode
IN00000 A-phase pulse input Pulse input Increment pulse input Increment pulse input
IN00001 B-phase pulse input Direction input Decrement pulse input Normal input
IN00002 Z-phase pulse input/Hardware reset input (IN00002 can be used as a normal input when it is not used as a high-speed
counter input.)
Interrupt Inputs
CPM2a MANUAL
yUO WILL ALSO NEED TO ENABLE THE HIGH SPEED COUNTER UNDER SETTINGS ON THE LEFT HAND SIDE AT THE PROJECT TREE
hey anyone, I'm a student from Indonesia.. I have a project, It is about how to send and receive data by serial communication between PLC Omron...
2,122
Hi All, need a little help in here.I never program PLC before but at the moment, I am task to backup PLC program on our machines which is using...
5,682
Dear Experts Help me to upload plc program from Omron PLC CPM2A to laptop. CPM2A name is not in the device type setting list of...
3,170
Dear PLC Experts, I am trying to go online with Omron Sysmac CPM2A PLC with CX-Programmer V 6.0 on Windows Vista Operating System. It gives...
9,758
Hello, I hope someone can help to resolve the current issue that I have now. I am using OMRON CPM2A PLC connected to the desktop PC so that it...
36,656
