CPU 1517F3 remote hardware chenges
Holmux
Oct 2013
Aalborg
279
Dear All
I realy need help with this one :)
TIA Portal v16
CPU 1517F-3 PN/DP
In my Profinet network I have:
6 of ET200 IO modules
1 of 1214FC CPU
1 of 1512SP CPU
3 of TP1500 comfort
80 of Movimot motors
I am connected via a VPN to X2 on the PLC, and wanted to add a module to one of the ET200 IO modules, (thay are all connected to X1 on the PLC)
After the change I cant connect to 5 of my ET200 IO modules, everything else looks OK
Any idea what I am doing wrong?
Found it, one of the electricians had connected a second PLC system to my switch with some of the same profinet names :mad:
Hello, I have a CPU 317-2DP Firmware Version V2.1.8. In TIA Portal only V2.6 is available, and there is no option to upgrade FW. Then I open it...
97
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
170
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
76
hello s7-400h and wincc are connected to each other via Ethernet. I need help on how to do time synchronization
70
I'm struggling to get an FR-E800SCE to work on CC-Link IE TSN. I'm sure the issue is with the drive, when I plug in the network cable I get no...
117
