CPU 43412A Run LED 4 Blinks and CPU is unoperable
tabrez
Sep 2004
aurangabad
27
Hello Everybody
Our CPU 43412A is not communicating at all....not even with the concept ..except EXECLoader ...Run LED Blinks 4 times.
it is in the "kernel mode" it says.
We tried downloading the EXEC file but just after the loading completes it goes to check the "waiting for the device to rejoin link this may take upto 60 secons" and give a message "Transfer operation failed" and "Exit kernel mode failed".
the crash code is 0405 and it change sometimes to 0404, these crash codes are not present in the CPU Error codes.
EXEC file is correct as we upload it from a similar CPU (As it is a part ot the redundant system) we have and we r downloading this same file to our faulty CPU.
Even though i loaded the .BIN file which came with the SR2 CD of concept 2.6 ...and same results and messages as stated above but i saw one stange thing when i go for the info in the EXEC then i found my faulty CPU has now a new .bin file which i loaded from the CD(This .bin file was having the higher version number and different name .
so i think loader did its job but the cpu communication is the problem or executable is not booting properly due to the hardware fault....?
When i read the specification of 140CPU43412A i observe that as remembered in specification 1. Local i/o : Maximum i/p and o/p words are 64 in...
502
Main rack contained power supply 140cps52400 and 140cpu43412A and RIO HEAD 140CRP93100 in addition to another I/o cards . Another remote rack...
1,869
Hi Every Body We Have Got Some Problem In The Cpu 434312a Which Is Not Booting And Effecting Other Modules Also (due To This Cpu Other Modules...
1,974
Hello all, I have a one problem. I would like to upgrade Mitsubishi PLC Q02 to Q03UDVCPU. I have Q02 program and I change to PLC type and try to...
150
Hello everyone! I need to connect to a DL205-1 CPU and, as far as I know, I need to use DirectSOFT 6 software for the connection. Is anyone...
68
