Create Alarm on panel view plus
ertech
May 2009
Puerto Rico
Hi,I have a compactlogix plc connected to a Allen Bradley Panel view plus oit and I Need to create and alarm (communication Fault) when disconnect the Ethernet cable. I appreciate your help.
Thanks,
Does the panelview not alarm anyway when you disconnect the ethernet...? Or do you mean that you want your plc to register the fact that the panelview is no longer connected?
I need it is possible create and alarm on the oit when the Ethernet cable is disconnected .
Explain a bit more please. When you say "Alarm" - what do you expect to happen? Flash a light, sound a klaxon, write a message to memory?
As curlyandshemp above says, as long as you have events checked off under "System - Diagnostic List Setup", there is an incredibly annoying and unclearable message banner showing communications faults.
These are not alarms, exactly, but system messages. You cannot signal their state back to a PLC device, but they will show up on the display, and can be printed out.
Hello! I am using Wonderware for past six months but still haven't fully cracked it yet! In my current application, on the alarms page I have...
1,210
Hi folks, I've been given some help already with PlantPAx which has been much appreciated, I'm looking for a bit more now though please!:)...
2,150
When creating an alarm for Panelview 800 I am getting the error message that an alarm is no message configured, but the text column to be...
2,341
How can I change location for DataBase. By default DB is created on D: drive and it is not enough space, I would like to move DB to another drive.
1,421
Hello; I am new on Intouch and I need your helps for my application. I have one set and one actual value on my program and I am dealing with the...
2,015
